I have no experience of those lamps.
I strongly suggest that you try one or two..
Here is an extract from an information piece
Filament LEDs.
First patented in 2008, but developed largely since 2015, are “Filament LEDs”.
The LED “filament” consists of multiple series-connected LEDs on a transparent substrate,
A benefit of the filament design is potentially higher efficiency due to the use of more LED emitters with lower driving currents. A major benefit of the design is the ease with which near full "global" (360°) illumination can be obtained from arrays of filaments.
Close-Up view of a LED Filament (at reduced brightness), showing the individual LEDs.
Shown below is a photo of a typical LED Filament Lamp
Here is a photo of a similar Lamp, which has been cut apart to show its construction.
Such lamps look very much like Incandescent Lamps and are constructed in much the same way, usually within a Glass Envelope – not a Plastic Envelope, as other LEDs often are.
Filament LED Lamps with “Frosted Glass” envelopes are available, although, perhaps, not enough are supplied.
Note that the “Control Equipment” takes up very little room and can fit within the confines of the metal Base.
While the actual “filaments” do become “warm”, there is less heat generated by the small amount of “Control Equipment” than with other types of LED lamps.
In addition, this heat is generated
within the metal Base, which is itself encased in a metal socket, both of which act as “Heat Sinks”.
As a result, Filament type LED Lamps
can be placed in enclosures which lack ventilation.
