Hotpoint HIC 3B+26 Dishwasher won't switch on.
16 Nov 2017
I have a Hotpoint HIC 3B+26 integrated dishwasher which popped the RCD, so I switch off the switch and reset the RCD and then when I switched it on again it just popped straight away.
I removed the dishwasher and opened and checked for blown components or any damage on the main supply lines.
I noticed that the cabling going from the main unit to the door had damaged the electrical tape and had bunched it all, so I removed this and free'd the cabling.
Powered the unit up again and then it ran for 20 minutes then popped the RCD again.
I then had to vacuum out all the water and then remove it again, I checked the wiring again and found a bare wire that looked like was shorting to chassis, it was going up to the latch switch. I taped this up after checking continuity and then when I powered it back up it won't even switch on.
The unit usually switches on before the door is closed as it's built in so the latch switch is open and then goes short once closed so take it that's the start signal.
I have checked the main PCB and there is mains power available to it, there is also multiple 12vdc on the pins that supply voltage to the ON/OFF switch and small control PCB, when the connector is removed when it's fitted this changes to a pulsed voltage so not sure if the top PCB is faulty or not can't seem to find any info or service manuals etc
Anyone have any ideas what to look out for as sound like a fuse but can't seem to see anything.
Should it power on with all the major components removed from the main PCB just to see if it was something else killing it?
Thank you.
Checked the mains supply and I have 230v AC with the plug removed from the control board but when connected the mains drops to 36vac I have checked the board for component damage but nothing obvious.
Just found splayed pins so sorted that and now mains stays high.
If the main door latch is made and the top switch board is removed the relay in the main control board fires.
When the switch board is connected the 12v is killed and nothing happens.
Have you checked for water leaking under the bottom into the floor side components?
No water leaking etc, I have found this component on the switch board that is a voltage regulator. Input and output pins only 1.6 ohms so doesn't seem correct. I will order and replace and see how it goes, could be killing the 12v going up to the board, as some of the pins beep to this component.
Replaced the component above and the voltages are back up at 12v but it got very hot. Checked other components that this goes to and goes to main plc and other parts so ordered a new switch module.
Fingers crossed.
hi, dg_pug106gti! I have the same dishwasher and the same problem. It drives me crazy for a couple years. Tell me please what is the “switch module”? Do you mean elements on the photo?
The switch board was the small PCB that all the switches connect onto. There was something on the board that was killing the supply voltage.
Replaced the PCB and all good after that, been running for a few years.
Thank you for your answer!
