Can a single rafter tie joist be cut for a loft hatch
1 Feb 2025
Hi folks,
Apologies for yet another variation on the question "Can I cut this joist to fit a loft hatch?", but I've not been able to find any examples similar to our situation.
The kitchen in our 30s semi is in part of a single-story side extension that replaced a lean-to garage, and its loft inspection hatch is a rather narrow (i.e. between adjacent 400mm centred joists) of 650mm x 360mm, which I'd like to extend - if not too big a job.
The roof over this loft is finished in plain clay tiles, pitched at about 37º, and extends 4m from a gable-end abutment at the original outside wall of the house, to a hipped far end. Its ridge is about 1.75m long, supported by six simple triangular trusses at ≤400mm centres, each formed from a pair of 6x2 common rafters tied with a 7x2 ceiling joist, with a 4.25m clear span. There are no other timbers, such as collars or purlins, and unfortunately, whilst the wood appears to have been treated, no ends are visible and no other obvious markings signify whether C24 or C16 has been used.
The photo below shows (most of!) one side of the loft roof - the house side-wall just visible on the right, alongside the six common rafters involved with the trusses mentioned above. The current inspection hatch lies between the 2nd and 3rd joists from the right - to the right of the highlighted rafter, which is the one that would need to be cut to allow a larger loft hatch.
Perhaps the roof has been over-engineered and the five remaining trusses would more than cope with the loads involved. On the other hand, it may be just enough as-is and shouldn't be messed with, and we'll have to live with the small access panel.
If something could be done, the small access panel and limited loft headroom mean that, whilst trimming a hatch outer frame would be fairly straightforward, it wouldn't be feasible to add sister joists - at least not without opening up the roof at the eaves to pass in timber. It may be possible to brace a hatch frame with some steel angle to effectively keep the two parts of the cut joist connected, but I'm out of my depth here.
I'd welcome any insights - is this an everyday situation with a proven work-around, a job for a structural engineer or do I save my money and live with things as-is?
Yeah. People do remove wood like that. I've seen it.
Some say taking one out won't make a difference.
Others will say it could cause problems. Get it looked at.
Others say cut out and watch for any problems.
Make of that what you will
OP,
According to the book, that should be no problem providing that you double up on all the hatch trimming.
However, without doubling up, your 7 x 2 joists & some noggins will probably allow what you propose without causing sagging.
Flooring panels will also support & firm up the hatch carpentry.
What you have marked, is called a rafter, and no you cannot remove it, at least not without bracing the cut ends. Why might anyone need to cut a rafter, to make a loft hatch larger?
No, why do you need to remove a rafter for a loft hatch anyway?
No rafters would be removed. The picture is to show the roof structure, and the truss that would be weakened - to provide context for anyone with structural engineering knowledge.
It's the joist connected the highlighted rafter (and barely visible, as it's buried in the insulation) that would need to be cut for the enlarged hatch frame.
OP,
Thanks for the info, @ree - that's very useful feedback.
Loft access would only be to install some ventilation ducts and maintain existing services - no storage. So, there'd not be any flooring panels in play.
If I understand the need to double up on all hatch trimmings, would something like the following suffice, if all 7x2 fixed with 80mm screws:
1. Scabs added to outside of joists extending beyond proposed opening, headers & noggins (in orange)
2. Supporting braces added across faces of joists and scabs (in yellow)
3. Double headers across each end of the hatch frame, plus noggins between joists (green)
150mm screws in the yellows would be better, if the yellows are 7x2. Strive for at least 2/3rds the screw in the substrate and 1/3 in the item being fixed. I'd also use 100mm partially threaded* screws in the reds and have the reds be triple the length they are in that pic.
And everything would be glued and screwed
*and aim for the smooth section of the screw to be as close to 50mm as I could get; when the thread does not bridge the joint the screw clamps the items together better. If the threading on the screws bridges the joint by an appreciable length, I use a grinder to rub some of mine smooth and establish the clamping before firing the rest in
Thanks @robinbanks I see what you mean about having a clear shank through the first timber, to focus on clamping - I'll use coach bolts if I can't find suitable screws, plus glue. I'll also make the orange/red joist scabs as long as the lengths of timber I can squeeze through into the loft.
That looks like a massive waste of wood and extra weight on the two joists. Just make a normal trimmed opening and span some 4x2 across the 4 adjacent joists to spread the load.
cdbe's version, was what I installed 40+ years ago, here, except instead of the two vertical timbers (in his drawing), I relied upon the eventual floor to brace it all. Perhaps not essential, but I added 8 extra steel L brackets - 4 to fix the cut short joist to the new piece of timber, then the other 4 fixing the new timber, to the uncut joists.
