- Joined
- 11 Feb 2025
- Messages
- 8
- Reaction score
- 1
- Country
Hi
Im after a bit of help. I've finally got around to pulling out a corner unit and can see possible rising damp. Last winter the wall was wet to touch, all the way up to above the concrete on the photo. Its on the start of an extension of a old detached house. Its obvious the previous owner has tried to do something to fix it or hide it
The damp in on the west wall. We had an old chimney removed last April from our south facing wall, we know this was leaking. I was hoping this was causing the damp problems and removing it would fix it.
The wall hasnt been wet this winter like last, but we've just pulled a unit out and wallpaper off and the very bottom of the wall is still wet. Its reading 33 on the moisture meter at the bottom of the wall and 17 were the wallpaper was wet historically.
Is this rising damp or could it be moisture from the chimney leak still in the wall nearly a year later? There wouldnt have been air circulating here because of the unit.
If it is rising damp is it worth installing dry rod?
Ive attached a photo for reference..... many thanks in advance
