This scenario terrifies me as it happens so often, plenty of threads on this forum.
The cause is normally the same
With wiring in the attic I wouldn't have known. I would like something more sensitive before smoke, melted wires and fire.
Many thanks in advance for suggestions.
Pg
My question, what socket can catch this before melting takes place, more sensitive to the resistance because it's not unheard of for melting to happen but fuse not blow. I've had it with a dishwasher and an electric heater, both moulded plugs (different sockets) fine for a few years then they go and it's only the smoke or smell that made it clear. No fuses blew.most likely a wire was not tightly gripped in its terminal. This creates a high-resistance joint which gets hot, as it gets hot it gets looser, so hotter, so looser. Eventually the junction between the wire and the terminal will burn away.
This most often happens with heavily loaded connections, such as the switches for electric showers. For some reason it more often happens with the black neutral wire.
Pg
