yet another boiler losing pressure thread
15 Apr 2018
Hi all
my boiler is losing pressure.
It seems to be only happening when we use the central heating which suggests that its a leaking component in the system.
Thing is this has been going on for a year or so ( we tend to use the log burner rather than the ch) so I would have thought if it was a hidden pipe we would have seen water damage by now and if it was a valve I would presume we also would have seen the water as we have bare boards. The pressure has dropped from 1.5bar to 0.7 in about 2 weeks (we have used the heating more than usual)
I have seen a suggestion to test every visible pipe and valve with blueroll, which I will do soon.
I have just discovered my homeserve covers me for plumbing leaks inc ch pipe/rads but not boiler work.
So is there anything to check on the boiler before I call them out? I will check the prv (bag over the outlet pipe)
Is there any other test where I can at least confirm if its the boiler or something else?
Thanks in advance
