I dont see the point? Why doesn't everyone have a mini roundabout like me? I just drive round and back out.
Do you know how the plate in your microwave spins?I've never owned a motorbike and I'm not good with spatial awareness. So please humour me! How does that small disc spin the whole bike? The wheels still seem to be on the ground.
When the supporting jack for the motorcycle is activated the tires will be lifted off the ground ensuring that they are no longer in contact with the surface. This allows the motorcycle to be fully supported by the jack. Once the jack is in position, it will enable the motorcycle to spin easily to rotate the bike without resistance. Get it now? If you haven't ever drove a motorcycle it might sound a bit weird at first.How does that small disc spin the whole bike? The wheels still seem to be on the ground.
Uderneath the sign there is an industrial Lazy Suzy that can support up to 2 tons, the sign is screwed to the lazy suzy and so I ride over it and position my centre stand so it is on the sign, then I simply push down on the back seat to raise both wheels off the ground and it turns itself. I can do it with two fingers as the centre stand is at the point of balance on my bike.I've never owned a motorbike and I'm not good with spatial awareness. So please humour me! How does that small disc spin the whole bike? The wheels still seem to be on the ground.
Uderneath the sign there is an industrial Lazy Suzy that can support up to 2 tons, the sign is screwed to the lazy suzy and so I ride over it and position my side stand so it is on the sign, then I simply push down on the back seat to raise both wheels off the ground and it turns itself. I can do it with two fingers as the centre stand is at the point of balance on my bike.
What do Kwikfit change lods of - and this bit is routinely changed with other bits when there's nothing wrong with it....your going to have to say then because I could go right through the car
Its a centre stand, if I didnt have a centre stand then it would indeed need a jackThanks. I thought that jack was just a kickstand like on a push bike!
tyres?What do Kwikfit change lods of - and this bit is routinely changed with other bits when there's nothing wrong with it....
@Mottie will know....
It is I have stopped using it for this very reason.A clearway is a section or road where you are not allowed to stop your vehicle for any reason, unless in an emergency.
Parking on a Clearway sign is clearly an infringement
not in your garage though is it numptyI dont see the point? Why doesn't everyone have a mini roundabout like me? I just drive round and back out.
