- Joined
- 2 Dec 2004
- Messages
- 731
- Reaction score
- 8
- Country
The tool should have lots of overhang over the brick. Mine has two ends, I always use the broader one for faces and the smaller just for internal corners. The broader one is probably double the size of a mortar joint and doesn't have that daft V shape yours does.
I think what it is is that the tool looks like a v shape because it's only the 1/2 size. The bit that's curved, is a quarter circle, but it's sitting within a larger piece of metal which makes it look like a tighter radius. If the joint was narrower, the tool would be sitting on much more of the brick and wouldn't go as deep.
For the width of my joints, I must need a much larger tool so it sits much more on the brick and therefore less into the joint. I didn't see any advice before I started this on which size tool you need to use unfortunately.
But anyway I've looked at some other houses around the place and many of them are just done completely flush. Do you think I'd be better off with that finish please?
And I'm back to thinking to use maybe some lime or sharp sand as well to give it a look more like what would have been there originally. Or texture it with a brush.
In your opinion if it was your house what finish would you use and what mix?
