Mine were similar to elements boards. Marmox multi boards. Cheaper too!!elements board, as it adds insulation properties.
Thanks for the reply. I like this idea but am worried that adding insulation will move the dew point to the cavity, meaning my cavity will get wet and it isn’t ventilated. I was hoping by building a stud wall and adding PIR, I could add a full moisture barrier to the whole wall before overboarding, does this sound correct?I also have a narrow cavity. On the window outside wall I have 72.5mm insulated PB (60+12.5) fixed direct, on the shower outside wall I have 2x3's on edge filled with PIR and overboarded with tilebacker cement board. It's been a perfect solution - we don't get condensation on the walls at all even with long showers - our extract is an inline over the shower cubicle. My house relies on the ventilated cavity to control interstitial condensation caused by the insulation resulting in colder internal walls. ( that's the theory anyway - so far so good). I would not consider CWI for this reason.
Eh?Thanks for the reply. I like this idea but am worried that adding insulation will move the dew point to the cavity,
At the moment condensation is happening on the cold interior walls of the bathroom, by introducing insulation, I am worried condensation would now happen at the next coldest point (the cavity). Maybe I am wrong, just something I have read.
