I have a INDESIT fridge freezer which the other day i was unable to pull out the bottom drawer.When i did manage to get it out i could see ice below & that was the issue as to why it was stuck. I removed the ice but after a couple of days its back again.
I read about blocked drain hose but not sure where it is.
Looking at the back of the unit at the bottom i see the condenser if that's its name, stumpy cylinder item which has a plastic tray above it.
The tray is dry & no water in it.
I also see a rubber part which I assume is where water is supposed to drip from into this tray, this is also dry.
In the freezer I have removed all the trays & taken off the back cover to expose the photo shown below.
Please can you advise any steps that i now need to take.
The 2 square windows either side had a lump of ice build up in both.
The is also a length of ice build up in front of the aluminium fins that you can see going side to side
Ideally I would switch the unit off but I have nowhere to put the frozen food.
Just some info for you.
I keep a temp gauge in the fridge above & that is showing 7/10 degrees.
The temp knob in the fridge is set to medium.
The food in the freezer is still frozen & not thawing
