I have fitted a number of bathrooms using PVC Shower Panels, and suspect the Silicon seal between the panels bottom trim and the bath lip has failed.
Where the panel meets the bath lip I have used Cladseal Shower Trim:~
claddingplus.co.uk
I am proposing to cut through the existing silicon seal between the trim and bath, and remove the bath, then hopefully prize out the Silicone, clean the bath lip, and refit with fresh Silicone.
I have a concern that I will not be able to strip out all the Silicone in the Cladseal Strip, nor fill it with fresh silicone, as the trims cavity for filling will be facing down, and the Silicone may simply droop and drop out before I get chance to re position and raise the bath into position. I've never used Silicone 'upside down' - so to speak.
I will assume my builders fitted the panels and trim correctly, but the bath dropping is the cause - the bath supports sit on 18mm ply spreaders, which sit on top of a 20mm rubber sound matt (to meet Part E), which has compressed slightly over the 3/4 years since this was installed.
To try remediate the dropping, larger ply pads have been put in place, and either a wall baton or some form of strutt between bath lip and floor will be provided, to keep the Bath Lip tight to the Cladseal Strips Silicone bead.
Cladseal Trim is supposed to deal with some movement though:
I wonder if anyone has had to deal with this or a similar problem, and could it be resolved in the manner I describe, or was a different approach taken.
Here are the Panels
www.panelcompany.co.uk
and
corner profiles:
https://www.panelcompany.co.uk/collections/trim-accessories/products/internal-corner (both from the Panel Company
Cladseal Shower Trim - Cladding Plus
claddingplus.co.uk
Here are the Panels
Shower Panels | Decorative Waterproof Panels | Panel Company
Upgrade your bathroom aesthetics with our range of waterproof shower panels, designed to elevate your bathroom interior with ease. Enjoy free delivery over £49.
corner profiles:
