- Joined
- 5 Nov 2024
- Messages
- 5,185
- Reaction score
- 2,431
- Country
Ah, apologies, thought you couldn't get the DC-1. You need something for the 45 socket to seal to unless you can solvent weld it?
do the 45 degree bends need solvent? thought they were just ring sealed pushfits? if not, putting in solvent is fine but have always read that solvent welds are somewhat risky especially areas where it'll be difficult to inspect.Ah, apologies, thought you couldn't get the DC-1. You need something for the 45 socket to seal to unless you can solvent weld it?
Well one end is ring seal, the other is either solvent welded or pushed into another ring seal, but you don't have ring seal in the receiving end on the grey pipedo the 45 degree bends need solvent? thought they were just ring sealed pushfits?
but the DC-1 would provide the female end facing up? then the male end of 45 degree go into that and the ring seal end of that would slot into the other bend; and the finally the flexi pan connector?Well one end is ring seal, the other is either solvent welded or pushed into another ring seal, but you don't have ring seal in the receiving end on the grey pipe
Yes, again apologies, I was still thinking about the dc-1 not being availablebut the DC-1 would provide the female end facing up? then the male end of 45 degree go into that and the ring seal end of that would slot into the other bend; and the finally the flexi pan connector?
Haha no worries. I'm just grateful for the effort and help.Yes, again apologies, I was still thinking about the dc-1 not being available![]()
Underground stuff is ok to use internally, the difference is, between Underground and Soil, the above ground has UV protection to prolong it its lifespan from the effects of sunlight. Look at any underground pipe and/or fittings that have been exposed to the elements for a few years, the colour is very faded and the plastic becomes extremely brittle.
The Polypropylene 'push fit' waste just disintegrates, sunlight degrades the plastic, it goes really brittle and crazed, then just literally drops to pieces. Many Plastic pipe manufacturers recommend their products are given several coats of a suitable exterior gloss paint to help protect and prolong their lifespan.
directplumbingsupplies.com
