Hi, I have a shed (old coal shed for Victorian property) which is across the driveway from the house. It has what I think is 25mm2 armored cable (looks like a meter tail) in it, that is connected to double socket in the shed, and to a plug socket behind the kitchen base cabinet!! Never knew where the power to the shed came from until ripping out the kitchen today, and finding this!
The shed is next to a car park space where I would ideally like to have my electric charger. The charger currently is at the side of the house - because I thought it would be too expensive today up and lay a cable.
The cable works fine, when you switch the plug socket off, everything dies, and never had any problem with the electrics.
So, I was thinking of getting a 10mm2 cable run to a junction box in the kitchen connected to this, and moving the EV charger to next to the shed which would be much better. I am laying floor in the next two days - need to make a call as to whether to buy and run the 10mm2 cable in the conduit from the consumer unit through to other side of the house where the kitchen is. I only want to buy it and slip it through if there is a good chance that cable can be used and a sparky would be willing to connect up to it and use it?
Any thoughts, or do I just disconnect and not only not have an EV charger, but now not have power in the shed either?
Thanks,
R
Thanks,
R
