- Joined
- 27 Jan 2008
- Messages
- 29,437
- Reaction score
- 3,617
- Location
- Country
We see reports and pictures
of tumble drier fires. The fire service gives advice, like
but the driers, well at least mine, are designed to set a delay start so it can be run overnight using cheap rate in the Winter, Summer cheaper to run during the day when sun is shining. The new version of mine, has an option to connect to internet, so one can turn it on when the sun comes out, even if at work, they are so clearly designed to work unattended, however that does not mean all are designed that way.
The big risk with a tumble drier is drying unwashed clothes, specially out of the kitchen, where oils and fats on the clothes can catch fire, and no warning given for that, I will assume the fire was with an old type, as it includes
with the advice, my heat pump tumble drier does not have a vent pipe, and since it takes around 2.5 hours to run the cycle, staying in the house while it runs not really an option.
Off-peak at moment midnight until 5 am, but about to change, so 2 am to 5 am, as they will then pay for solar export, so in Winter when not enough solar, it will run 2 am to nearly 5 am, and I think the risk of fire with a heat pump tumble drier is very low. Clearly always a risk, but it is like telling EV owners not to charge their cars overnight.
