- Joined
- 21 Jun 2013
- Messages
- 4
- Reaction score
- 0
- Country
I have a free standing tumble drier which is meant to slot into a space under a worktop. There is a vent connection at the back of the space, which is ducted to outside.
I have to connect the drier to the vent connection with a flexible hose before I push the machine back into the space, because once it starts to slide under the worktop there is no access to the back, because there are units on either side too.
To get the drier to fit flush under the worktop, I have to push it all the way back until it won't go any further, but I am worried that the metre or so of flexible vent hose will end up crushed or kinked behind the machine when I push it back, preventing the machine from venting properly, and potentially creating a fire hazard.
Is there any trick or special method to overcome this? Is there any reliable way to check if the airflow is what it should be once it's in place (there is a mushroom cap over the end of the vent outside so I can't wouldn't easily be able to tell what flow rate was coming out)?
Thanks in advance for any advice.
