No it doesn't need to be tapered, overthinking it now. What's the gap between those studs? Looks more than 600 but photos can be deceptive.
Thanks. People say to use construction glue for shims but wondered if using D4 wood adhesive is ok here?OK with those extra yellow studs that'll be fine, you often have to do a seemingly less than ideal board configuration otherwise you end up wasting a load of material as it's only available in slightly weird sizes, as you say just use plenty of fixings it will be fine. As mentioned provided your spacers are adequate and solid and under every screw it'll be fine.
No, if you look at the photo of the existing section, the Hardie board will be at the same level with it.Does the architrave not cover it?
Yes, that's what I was thinking is only option but difficult part of finding a packer to fit this width and depth will be difficult (32mm width and depth probably 25mm ish - although guess depth can be slightly flexible depending on thickness of tile adhesiveRemove all the architraves, fit a suitably sized timber packer to your jamb next to the tiles then refit the architrave to that one. Then fit new bigger architraves to the head and right hand jamb.
Window packers would help with making the architrave the right level with he tiles and every will look fine only is looking at the tile head on. The packers would then be visible from the side as you walk in. Haha guess then I would still need to find a strip of wood exactly the right size and angle to fit perfectly which mag even be harderWould window packers work?
