Currently fitting a shower bath into the corner of our bathroom. Short edge is against a stud wall covered in Aquapanel. Long edge is against a brick wall, covered in dabbed & screwed Aquapanel. Have just tried the bath for fit before I finish fitting all the Aquapanel. As I feared, I haven't managed to get the panels perfectly square to each other.
The best fit I can get means that in the corner I have about 6mm gap between each edge of the bath and wall, tapering down to nothing. This is a bit more than I'd like, but have no idea on what is considered good enough in this situation. This is the corner under the shower so want to ensure no leaks later on.
The plan is to silicone between bath and aquapanel, tile down to top edge of bath then more silicone between tile and top of bath. Before I go any further, is the gap I have between the bath and wall too large to fill with silicone? What sort of gap should I be aiming for?
Assuming I do need to improve things, my first thought was to get the bath tight to the long edge and adjust the stud wall on the short edge to close the gap up, using some thin wood or packers between the Aquapanel and studs. I have a feeling I've seen that done somewhere before but can't think where! The other way would be to rip the dabbed boards off and have another go at getting them on square this time.
