Hi all,
Hoping someone here can offer some guidance or a second opinion on an issue my mums facing facing with her heating system. Apologies in advance, i know not much about heating and /or boilers, trying to help my elderly mum out as she is super stressed with this. Here’s the situation:
At the time of installation, we were told the system had been cleansed to British Standards using MC3 and MC1, but no powerflush was done. Have confirmed that by looking at the installation form that was provided at the time.
A few days ago, she lost both hot water and heating. Here's the timeline:
Have called the boiler engineer back out to reassess.
Setup:
- Worcester Bosch 24Ri conventional boiler
- Installed ~5 years ago by BOXT
- Hot water cylinder in the airing cupboard with a pump and 3-way diverter valve
- Cold water tank in the loft
- Boiler has been serviced annually and is still under manufacturer warranty
The Issue:
- We called a plumber who checked the system and replaced the 3-way diverter valve, but it didn’t fix the issue. He wasn’t Gas Safe registered, so he recommended we call someone qualified to check the boiler, as he suspected it could be the problem.
- Since the boiler is under warranty, we contacted BOXT. They arranged for a Worcester Bosch engineer to attend. He inspected the boiler and said it appeared fine, but used a magnet on the pipework in the airing cupboard — it stuck, indicating possible sludge or buildup. He said there was likely a blockage and left.
- We then brought in a Gas Safe heating engineer who confirmed the blockage. He replaced sections of the pipework and the pump. The engineer now suspects the boiler’s heat exchanger is blocked, as he had the return pipe from the boiler open-ended and found no water passing through — despite the system being full.
My Questions:
- Should this kind of issue be covered under the warranty?
