You will most likely just end up with milky mark if you try this on a polished surface, The hot steam trick is used to get dents and scratches out of timber, as in bare wood, not wood that has a finish on.Try the old damp cloth and hot iron trick for the scratch.
And TBH, you may have better luck with some felt pens or bit of coloured wax than trying to get a perfect finish when you are really just messing about with trying to get a French polisher's finish.
Again this only works on bare wood as it relies on the sawdust from sanding the wood to stick and colour the glue.
You will have to do test stains/varnishes to get the best match, anything slightly different will produce a finely finished scratch. Don’t rule out re sanding the whole surface and varnishing from scratch. I have found danish oil to be consistently good, just experiment with different stains to colour match, it won’t be perfect.I have this deep scratch in the surface of a cupboard and i'd like to see if it can be solved. What colour should i look for to best match the marked area?
Thank you Oops, I am happy giving any advise I can, the main problem is, and this thread is a perfect example, it’s very difficult to explain in words how to touch out a scratch, as I said in my original post so many different factors come into play. The other difficulty is even if could easily explain it, obtaining the correct materials in small amounts is not possible as even the smallest tub of something is way more than you would ever need, to get set up with the full range of powders and dyes and a couple of different size brushes some French Polish etc, you would spend a fortune only to use a dash of each. I will keep trying though.I am a lowly decorator. I have only attempted to french polish handrails. I was "content" with the finish, but I would not consider doing a wider area.
For the benefit of the rest of us, and other people that read this in the future, I hope that you are able to share more of your knowledge. I for one would be happy to learn from your 30 years of experience. Yeah, anyone reading your advice will not be on your level of expertise, but people on lower incomes (of whom there are many), the kind of people who would not commission you, might be able to find a middle ground for themselves.
Warmest regards.
