I've seen it done with a 9in portable circular saw a few times, and I use PCD blades on circular saws for cement board, but I'd hazard a guess that when you saw it being done it was using a 10 or 12in (250 or 300mm) disc with a 1in (25.4mm arbor). You can easily get abrasive and diamond discs in those sizes. However, the OP's saw is 185mmI've seen it done and had a masonry blade (abrasive type) in an ancient table saw myself before I invested in a proper (wet) tile saw.
OP,
Dont use an angle grinder - carry on with your circular saw: you will have much more control.
Mark the cut line - set the guard for a 5mm nicking first pass, & increase the guard depth by 5mm increments until you have reached the desired depth.
As above, dont force the saw, allow it to slowly go forward with a little pressure.
From the edge of the material. Making cut outs or doing cuts requiring plunging cuts into concrete is probably best done by a water jet cutterAssuming that it is not a plunge saw with a retracting riving knife, how will the op start the cut?
Ah, but most angle grinders currently have abysmal dust extraction unless you shell out for a special dust extraction kit (there are exceptions such as wall chasers), however those kits are the preserve of trade quality grinders, so maybe a bit of red herring.And what about dust extraction? Angle grinders are designed to deal with (some) concrete dust, circular saws less so.
That'll work well with a 230 volt electric saw...When I've seen it done, there has been a constant water jet on the cut.
