- Joined
- 6 May 2025
- Messages
- 212
- Reaction score
- 74
- Country
Certainly would be.
TBH cutting mass concrete is really a job for a Stihl-type saw (which do have water suppression as standard these days) or possibly a large angle grinder. But it is a VERY dusty job. Accuracy within a couple of millimetres either way is generally regarded as acceptable (i.e. all you'll get in practice).
There are concrete saws which run on rails, use sintered diamond cutting discs and can do a precision job (e.g. Hilti), but they make @opps' Festool wall chaser look like a toy (and I believe the biggest ones cost almost as much as a small car).
What the OP's saw could do is cut hard cement-based materials such as cement fibre board by the addition of a 185mm PCD blade, but PCD blades probably wouldn't handle the aggregate in concrete and the teeth might shatter. Again, cement fibre board cutting is a very dusty job.
So unless someone can come up with a source of 185mm (or slightly smaller, down to about 160mm) stone cutting discs with (presumably) a 20 or 30mm bore, then the OP is out of luck
