- Joined
- 15 Jan 2025
- Messages
- 187
- Reaction score
- 5
- Country
Hello all! I am planning to repaint an interior door in my house which is badly in need of it.
But this door has a previous coat of paint, in a glossy magnolia shade which has a very smooth surface (on the parts where it hasnt flaked off)
And i know from experience, that this surface will not take paint. Not well, at least, it'll struggle to adhere, and even when dried, the first coat will slide off from the force of the roller when i try to do a second coat. I really ought to do something about it before applying new paint
This isnt the first door ive worked on like this, it'll be my third. For the past two, i used the same strategy. I set my belt sander at 40 grit, and spent about four hours on each door, meticulously stripping every tiny fragment of paint off them.
This worked! But its not a perfect solution.
For one, it was a little costly, i went through about five sander belts on each door
Secondly, its pretty destructive, the door surface was noticeably thinner afterwards, i suspect that if i tried to repeat process on onne of those same doors, it'd cause holes
Thirdly and most importantly, the fine particles of sawdust being kicked everywhere cause a mess in every corner of the house, it took me quite a bit of effort to clean it last time, and i have resolved now, to stop using the belt sander indoors
so i need another way, any ideas?
