Hm, we actually use morrells two component paints in the workshop, need to bug my boss about it. We have distributors close'ish.
Possibly a 2k formulation. Requires masks, spray gear and a dry back booth, so not suitable for home application. By- products of spraying are potentially toxic (hence the masks, extraction, etc)
On a side note, anyone tried the food colouring wood ? seen some examples on youtube with some good results.
Food colouring isn't all that light fast, is it?
Looked on temu for some alcohol dies, there are plenty of concentrated stuff, might give it a stab.
Try "tasteofeast-2013" on eBay for Morrells rather than importing some Chinese crap half way across the globe , - currently £8.95 for 250ml of Morrells green, delivered. At least with Morrells you can get spec sheets
The general idea is to yakisugi a board that is a handrail in my house, stain it green after brushing and lacquer the heck out of it. Will not be french polish as yakisugi is well textured by nature, but will see what happens.
French polish isn't mirror finish naturally - to get that you need to fill the grain, scrape then apply many coats of finish. 3 coats of French polish on an open-pore timber like oak will show the grain and pores (which I presume is what you mean by "textured"). The glossiness of French polish is down to the number of coats and the skill of the polisher, but too high a gloss can be dulled down a bit by using a mild abrasive such as rottenstone. Be careful if attempting to apply stain over a lacquered or polished finish as it can end up looking very inconsistent if brushed on (spraying is best approach). Test materials first to check for compatibility, but note that a thin inter-layer of white (blonde), dewaxed French polish often allows two incompatible finishes to.be used one above the other
Ideally i'd like to get my hands on some maple, as apparently it dyes and french polishes very beautifully, but at the moment will try texturing/colouring cheap wood.
Almost any hardwood French polishes well - softwood on the other hand is generally a waste of effort TBH
You can texture softwood (i.e. accentuate the grain), especially in timbers such cedar and Douglas fir, by scorching it then raking out the charred summer growth with a wire brush, thoroughly. Scorched timber will need to be sealed thoroughly (ideally by spraying) before attempting to stain or lacquer/polish it because the black charcoal residues will "taint" any finishes, especially if applied with a brush or roller
