Taping and tanking backer board (and niche)
4 Jan 2011
I’ve spent hours trawling through previous posts, here and elsewhere, about taping and tanking backer boards and I’m left feeling a bit bamboozled. Different products, different combinations of products, different contexts, different opinions…
Builders have done the shower room in a new loft conversion and I’m now doing the tiling myself. They’ve fitted 12mm hardibacker and built a custom niche from the same.
My current plan is just to buy the mapei tanking kit: prime everything, gum the tape on to all joints and corners, then tank. I may buy the preformed corner-tape section or may just work it out myself.
Does that sound right? Or do I need to use a sealant product (CT1 perhaps) on the joints before applying the gum and tape? I saw someone use scrim and mortar and then apply the tanking tape but that just seems excessive!
Thanks!
Your first ‘version’ is correct - Buy the tanking kit, paint it on. Use the tape that comes with it to go over the seams/joins. No need for any preformed corners or CT1 etc.
When I've done ours I've used the hardiebacker tape and then trowelled on some tile adhesive over the joints as you say.
I've not used the Mapei one. I tried the Everbuild kit which I thought was rubbish. I can certainly recommend this one though and it comes with two corner pieces.
https://www.protilertools.co.uk/product/tilemaster-tanking-kit-waterproofing-tub
Use the paste and then apply the tape/corner pieces, then you can go over them again and apply everywhere else. I've always done a small overlap with the tape at the bottom, over the tray edge.
