- Joined
- 15 Jan 2025
- Messages
- 185
- Reaction score
- 5
- Country
Hello all, i did recently paint a windowframe, which is made of plastic. I knew that paint would never stick to smooth shiny plastic, so i went and got some special primer for it
This stuff is a thick grey paste, and i know from my warhammer days, it smells exactly like the Plastic Cement i used to assemble models back then. I'm sure it's a similar kind of substance, being highly corrosive and primarily working by partially melting the plastic
Anyways this process went well, overall, once primed the surface took paint easily, and now the windowframe looks wonderful. But there were a few hiccups in the process. And now i find myself on the eve of repeating it all for a different windowframe, i'm wondering if theres anything i can do to refine it:
1. How thick is primer supposed to be spread? I tried to play it safe and went for total coverage, every millimetre of plastic was covered in a smooth grey, not a bit of the white underneath remained. But this came at the cost of using 75% of the tin on that one windowframe (i got two tins so im good for the next job). I cant help wondering if i went overboard, and spreading it thinner might have been fine
2. The corrosiion is a bit of a problem, i used a small foam roller, 4 inch length, and by the end of the process, this stuff had just devoured the roller, it fell off and was forevermore unuseable. Maybe theyre meant to be consumable anyways, but i'm thinking foam isnt the best material, is there something more suitable?
any other insights on priming plastic are welcome
