Hi all,
We have a Potterton Promax 24SL system boiler, now around 13 years old. It’s been running reliably overall, with no noticeable issues until the past few months.
Occasionally, we’ve noticed a few drops of brown liquid leaking from the front of the casing — maybe 3 or 4 times over the last 6 months. The most recent instance was in March. Otherwise, the boiler is working fine and the pressure remains stable.
Due to the intermittent nature, i assume its a very slow leak under certain conditions and when cold stops?
We recently had an engineer out for a routine service and inspection. They spotted some leakage and staining around the flow and return connection points at the heat exchanger and manifold. Based on that, they suspect worn seals and recommended a boiler replacement rather than repair, citing potential issues with seized fittings and difficult access.
Has anyone experienced similar issues with the Potterton Promax 24SL and gone down the repair route successfully? I'm trying to figure out if replacing those seals is straightforward maintenance or if it's as awkward and time-consuming as suggested — to the point that replacement really is the more practical option.
Would appreciate any thoughts or shared experiences!
Thanks in advance.
Hung
Thanks in advance.
Hung
