I was told 1966 the rules changed on lighting and earths, but the 13th said when allowing no earth.
(ix) Lighting fittings using filament lamps installed in a room having a non-conducting floor, mounted at such a height that they cannot readily be touched and are out of reach of earthed metal.
So my parents house with wall lights, needed to have those wall lights earthed. And also fluorescent lights have always required an earth.
As to TT, it seems likely most homes with TT the water pipes although technically bonded to the earth rod, in real terms the water pipe was a rather good earth, good enough so a line - earth fault could rupture a 13 amp fuse.
As to when the ELCB-v arrived on the seen, not sure, seems odd, but only found them after the rules had changed, and no longer fitted. But clearly as water pipes got changed to plastic, something needed to be done. I never saw one of these
in use, in fact even when the RCD hit the scene, it was many years after before I saw my first RCD tester, only after they became a requirement for out door equipment did I see the test set. And I can see why we need the test set, as so many failed. It only needed a bit too much strain on the cables, and it would warp the plastic slightly and if they did work, they were well out of spec.
I would say 2004 and Part P was the game changer, electricians had to raise installation certificates, and wanted to actually test, not simply guess it will be near enough.
Still commercial lagged behind, even if an installation certificate was raised, minor works for alterations were rare, so was actually getting a copy of the regulations until it became BS7671, then it seemed to change, people were sitting exams to show they could read.
