- Joined
- 13 May 2021
- Messages
- 161
- Reaction score
- 6
- Country
Just finished the single skin blockwork for my double garage and moving onto the roof next
The double door opening has a steel in position, the top of which finishes at the same level as the rest of the walls (side and back)
I now need to move onto building the flat roof structure and am trying to figure out the most appropriate way to do this.
The roof is going from back wall to front (steel end).
What are the options here for fixing.
1. Wall plate fixed to back wall with mortar and strapped, and bolted to steel at front, rafters across from front to back fixed with nails, twist straps used to fix every other rafter to the walls.
2. Rafters straight on top of steel and ontop of walls
Q. Here, how are the rafters fixed down to the blockwork wall and the steel itself?
Q. Either way, when I get to the side walls do I fix a rafter to each side wall? If so, how as these side walls will not have a wall plate?
