Replacing TRV valve
15 Jul 2013
Hi, i have leak coming from trv valve see picture circled. Have had few people come round to fix but either didn't get bk to me or turn up. So I'm thinking is it do able myself? As it's leaking quite bad now and going under floorboards and need this fixing asap. Watched a few videos on YouTube doesn't seem overly complicated to replace just worried about the amount of water that might come out? Any tips on doing it?
If you release the pressure through a bleed valve be a few pints of water
then you should be able to change it with little to no water coming out , shut the valve off on the other side of rad beforehand
Thanks for the reply, yes I will do that do I need turn off boiler?
You’ve circled the connection between the valve and the pipe. You may not need to replace anything; just dismantle it, clean up, and reassemble carefully with some PTFE tape around the olive.
Personally, unlike @gaz112, I would not try to do it without draining the system to below the level of that radiator. But I’m just an amateur! The pros have some anti-gravity magic that makes the water not fall out.
It's called a vacuum - if air cannot get in to replace it, then the water will not leak out.
I would suggest closing both the lock shield valve off, and the TRV - your only possible source of water loss will then be via the disconnected pipe. any accidental flow from that, could then be easily stopped, with your thumb, or more permanently with a cork.
The radiator is now off the wall and both sides are supposedly closed but the trv still has water coming out of it when hot water is turned on (faulty valve?) and boiler also sounds like alot of air in it do I need add pressure?
Ok, for now, turn the boiler off then. Hot water on? - definitely a combi?
Why have you taken the radiator off the wall?
You’d expect that, right? Based on where the leak is, between the pipe and the valve.
If it’s basically working now, wait until you’ve fixed the leak and then worry about repressurising.
Yep definitely a combi valiant 1 year old. Radiator is off wall to redecorate but seeing as its causing so much problems it will be going straight bk on. Looks like il be getting a plumber out for this one. Thanks for the replies
