No it doesn't. There's a window in the way, plus the way it is currently routed to run alongside the pressure relief pipework is the neatest way of doing it.Does the conduit run vertically directly to the loft space, if so can that be moved to where the heat pump is to avoid having the bend/enclosure?
The best way of doing it then would be to use rigid conduit pipe? I was looking at the galvanised steel conduit which is presumably the best option but then not sure if you can run angles with that. I'm guessing not.
