Again, happy to be schooled but how so? As in - how would the water track into the cowl?
If mine let in the Niagra Falls, the open pots to the right must let in the Pacific Ocean.
When the rain hits the flaunching, there will be a certain amount of rain bounce, some of which will get into the flue. Some will also pool slightly and run into it.
It won't be a massive amount, and as with an open chimney pot, when the flues were brickwork and parged a small amount of water would be soaked into the parging and easily dry out.
However, once a stainless steel liner is in the flue, a small amount of water will run down into the appliance. This can damage the appliance over time, so ideally you try and keep as much water out as possible.
What you've got would be better sitting on top of a chimney pot.
The gap on the sides is gigantic!!!!!!!!
Absolutely, but that gap sits sideways on. The open pots sit facing the sky like an open bucket.
My cowls have a large overhanging hood and the flaunching slopes away from them.
I figured this must be enough to keep most of the rain out, but I'm not confident enough to say for sure hence starting this thread to see what others thought.
I agree with this assessment. Rain will get in as described. The flouncing is relatively flat and water will pool and it will get blown down, espicually on the side of the neighbours as that is higher and nowhere for collected water to go except down your flue. If it is to stay like that then possibly add something around the base up to the first 2 mesh holes. 1.5 inch strip of stainless steel bent to a square riveted in place, sealed with lead mastic at the bottom - but that is a bodge fix for something that should of been done better from the start.When the rain hits the flaunching, there will be a certain amount of rain bounce, some of which will get into the flue. Some will also pool slightly and run into it.
There you go a proper expert. By the way I did not realise the flu was active.Normally any flue work either remedial or new is notifiable work to the local authority under the building regs.
You must be either Gas-Safe or Hetas registered to self certify your work.
A roofer (or builder) will not have the knowledge or qualifications to do so...and the qualifty of the work shown is evidence of that.
Over the years I have encountered many situations like this that have left the occupants in serious danger (some flues have completely failed to draw through badly installed liners). You should note that all solid fuel and decorative gas fire burn with very high levels of carbon monoxide, cooker and boilers are much much safer.
Those bird guards are designed to fit onto a square section chimney pot. They are normally available in different mesh sizes depending on whether it's serving a gas or solid fuel appliance (the regs specify the size). The suggestion of covering up the lower holes is totally irresponsible.
For a disused flue you would install a rain cap onto the chimney pot - they almost close of the terminal allowing a little air circulation up the flue to ward off damp.
The rear flue liner appears to be sitting at a height that may well obstruct the combustion products. Is it the correct diameter for its use? Have suitable clamps and plates been used to secure it etc. Was the existing flue thouroughly cleaned/swept?
As for the flaunching I normally use a 50/50 building sand/sharp sand at 3:1 with SBR/water to waterproof the capping. Use broken tiles to build up the thickness.
All new liners must have a data plate fitted in the property giving details of the liner manufacturer, it's suitable use, compliance etc.
There are multiple standards regarding flues.... Document J, BS 5440, BS715 etc. detailing the requirements.
I suggest you find someone suitably qualified to check/redo the installation.
Designed to sit on top of a pot, I'm not sure why you didn't reuse the original pots; they look okay.What you've got would be better sitting on top of a chimney pot.
I'm wondering if the builder wrapped them in bubblewrap before placing them carefully in his van.Designed to sit on top of a pot, I'm not sure why you didn't reuse the original pots; they look okay.
Haha wonder no more my friend, they're in my garden.I'm wondering if the builder wrapped them in bubblewrap before placing them carefully in his van.
What are building control charging you to get the install/flue work checked and signed off by a Hetas installer, although any installer is mad to sign off others work (when they can't really see properly whats been done), in the gas trade it's banned.
This could all come back when you sell the property....solicitors want all the paperwork in order.
