- Joined
- 2 Dec 2004
- Messages
- 716
- Reaction score
- 8
- Country
Hi.
I am boarding my loft for storage.
The existing ceiling joists are small and only able to support ceiling load. I therefore need to build a new timber floor over the top of the existing ceiling.
I have already completed two sections, where I was able to utilize existing brick internal supporting walls to rest new joists on. I attach two photos of completed sections.
My third and final section is more tricky as I need to span across to the outer wall of the house as there are no other solid walls I can use.
My issue is how to rest new 7x2 joists onto the existing wall plate, when the existing rafters at a 45 degree roof angle limit the available bearing for the new joists. I attach a photo showing the final section I want to board.
If I cut the new joists at 45 degrees I will compromise the bearing end substantially.
I'm happy to include some extra pictures or diagrams if it helps explain the problem I need to solve, please let me know what you would like to see.
Thanks.
Thanks.
