Cooling tips
Exactly, mine takes several days to aquire heat, then several days to loose that heat.
Here is today's temperature graph. Yellow internal, blue external, showing a sudden fall at 16:20, when we had a few drops of rain delivered.
I've been puzzled by that sudden hump, in the yellow trace, for the indoor temperature log, at around 5:30 am. I have just worked it out, it was due to me, closing the the front and rear windows. I have a similar trace, and rise, for this morning. The rise is the heat rise, from the internal house fabric.
Most modern houses have little thermal mass inside the insulation envelope, It allows rapid warming up on cold days, but without air con, it’s difficult to make houses cool.
I personally think we consider houses with: exterior wall insulation, have high density concrete blocks on the inside and floor insulation below the concrete and screed.
I wonder if underfloor heating can be turned into underfloor cooling
We were on a tour of India in 2023, rail and coach, after every visit to a tourist attraction ( the heat and humidity were fierce) our coach attendant produced ice cold Cobras, a nice little earner for him
Edit We took some rechargeable hand held fans which were a god send at some sites, even our local guide was feeling the heat
The one time I went to Delhi- the only thing I drank over the week I was there was Cobra- nothing else. I was paranoid about Delhi-belly.
The day I got back to the UK, the skin on the palms of my hands and soles of my feet started falling off. For 2 weeks I looked like a leper. One day I pulled a 7" long piece of of skin off my feet. Didn't hurt, but it was embarrassing. GP had no idea what caused it. Naturally, I didn't blame it on the Cobra. I still drink it when I go for a curry.
Tell me - what building reg's do you know of that are in place...
for keeping homes warm without one thought to how they will keep them cool
Prey tell?
I am actually interested in this issue. It is commonly said that many new homes get too hot. Is that even true. If so, what are the causes?
Any house with a roof will get warm in the summer sun. The better they are insulated, the lesser the effect of the sun. Those houses with poorly insulated walls and things such as conservatories will contribute to warming.
There is zero logic to this though...
Insulation, just delays the inevitable.
The stupid consecutive governments have put in place building regs for keeping homes warm without one thought to how they will keep them cool.
Do you mean just by circulating cold water through it? If so, the temperature difference wouldn't be sufficient to provide any meaningful cooling.
Although, presumably if you have an ASHP, you could reverse the cycles and pump very cold water (say 5 degrees) through the whole heating system. Both underfloor and radiators. That should be enough to cool a house by a few degrees. Radiators might not work well in reverse, though, because they mainly work by convection.
2 or 3 litre bottle off flat pop /diluting juice half full placed in a freezer lay flat overnight or at least 4 hours
another 1 or two full bottles in the fridge
in the morning fill the frozen bottle from the fridge bottle
transport in a coolbox together or lay on a seat or other surface together and cover with anything cloth or fabric to keep cool
keep decanting into the frozen bottle then you will then have ice cold to cold drinks all day
if you cant lay the frozen bottle exactly flat just make sure the neck end is upper most
Thanks, but doing all that made me sweat like a horse. :(
