Sockets aren't working (Ed.)
Luxury - we had just the one socket in the entire place back then.
Is that when these were invented?
Update for everyone the fused unit is in the kitchen and I don't know what it controls it is far from the diner room so I'm getting an electrician to check it tomorrow.
What you need is a socket tester.
If next time this problem occurs, simply plug it in and it will tell you whats going on. If nothing tripped, that suggests a loose connection which can easily be known by using a plug in socket tester.
View attachment 385469 Yes, you can plug it in and be sure it is dead! Really, how does that help? Socket testers are a good tool when caravaning abroad as it will show line - neutral reversal, and will show lack of an earth, but for the problem in hand, would not help one iota.
Usually, you like mentioning socket testers all the time, don't you?
In the OP's case, he or she can check which sockets have power and which do not. If none of them have power, then there's a good chance that an MCB or RCD has tripped, or there may be a loose connection. If one or two sockets have power and the rest do not, that would suggest a loose connection at the last working socket if its a rdial.
Update! It was a breaker in the off position how did I not notice that!! Thanks for the contributions. Accidently forgot to turn it back on after changing a socket. It turned back on and everything is functioning.
At least 4 times we asked for a photo of the consumer unit, none were provided - might have saved you a callout electrician charge:unsure:.
Glad you're sorted.
I have looked at socket testers with loop 1751017449563.png and most will pass at around the 1.7Ω to 1.9Ω mark, where the pass mark for a ring final is 1.38Ω so they are only any good for radials, and in the UK in the main we have ring finals.
A bit of hunting and I found
this will measure low enough, and also does the RCD ramp test, and will record the time taken to trip. So seems a little pointless getting a plug in tester with loop.
Without loop test 1751018394561.pngare they worth it? Do they give a false sense of security, and for the full-blown tester, ELI-on meter.jpgcan the DIY person work out what they are looking at? As to be frank, I have failed to work out what the 0.01 refers to, press a button Loop-test.jpg and yes loop impedance shows, although only one decimal place, and the RCD test is spot on, but what was wrong with plugging in a standard lamp?
