Issues with dusk to dawn lights
11 Nov 2008
The lights were working perfectly for over a year , then noticed that one of them wasn't working , so turned off at the mains switch , the light came back to life and was working fine for maybe 30-40 + minutes , then back to the same..... only one working , and idea what this is and how to fix as I can't seem to find the same light anywhere.
Mine are hard wired , today after a reset they are still working 2 hours+
My dusk and dawn functions I think come from the internet, so a car parked slightly different, stopping the Wi-Fi signal could mess them up.
You can get ones which detect actual dusk and actual dawn.
I believe they use something called a "photocell", and they aren't confused by parked cars.
Dusk and Dawn are fixed times each day,
my outside light is set to turn on at 5 am and off at dawn, plus an off at 9 am to allow for this time of year, 4 days a week that lines up with my milk deliveries.
I have somewhere it is set in the bulb, and other set in the switch, I do have one PIR lamp, but that has nothing to do with dusk or dawn it works purely on light levels. There were mechanical switches, ⁣but
these have been in the main superseded with electronic switches. You can get bulbs
with photocells built-in and sensors
which in some cases are built into the lamp, but these work on light levels, not times.
I have a light either side of the door , one works one won't come on even if it's pitch black unless I turn mains off then on
Replace the photo cell in light that doesn't work or if that isn't possible override them both (disconnect inside the lights) and fit a new photocell to control both.
Any idea where I can get new photocell
This is the light
Of course, you did not state the Brand/Model of the Dusk to Dawn sensor concerned.
However, such devices utilize some type of Photo-Sensor,
which usually Fail/Deteriorate - within about ten years.
If the Photo-Senser is integrated within the device,
the entire device needs to be replaced.
One should never utilize a device with an integrated Photo-Sensor - because of this reason.
Always have a separate Photo-Sensor to control any such device.
In that way,
when the Photo-Sensor fails (as it will) it is necessary only to replace IT.
I use a smart switch, "Tapo"
it does need a hub as well, uses a battery so does not require a neutral or a load, and it supplies the old PIR lamp outside, so it only works dusk to 10 pm I could set up dawn, but there are other outside lights. And on the odd time I am late home, I can turn on lights before leaving the car.
It has dusk and dawn built into the switch, and timers. The tapo hub
doubles as a doorbell, with a button,
it was not got to do that job, it was to turn bedroom lights on/off, but wife uses Google Nest Mini's and voice commands, so it was not being used.
Now that is a good idea, What on earth did we do before the Inter-net took over our lifes
If you wanted dusk to dawn, you used a photocell. If you wanted on at dusk, off at a set time - then you used an expensive, complicated, Sangamo solar time-clock. Wifi smart switches/plugs, make either process so much easier, and cheaper to implement.
