I can remember all the way back when a good labourer was able to feed two very fast brickies via barrow up a couple of s-boards straight from the mixer. Worth their weight in beer a good labourer
What happened when they got to the gable ends? Use spiral boards?I can remember all the way back when a good labourer was able to feed two very fast brickies via barrow up a couple of s-boards straight from the mixer. Worth their weight in beer a good labourer![]()
Once the mortar has begun to set
Not necessarily. It all depends how long it has been stood.
I doubt scally has been anywhere near a building site let alone a barrow of gear. Seems like trolling to me. The presence of water is far more important to mortar than the absence of it.To be realistic, on hot days the mortar will often be knocked up again
Nonsense.Also 'knocking it up again' grossly weakens the mixture.
This..Probably won't crack the bricks like all the others on the estate when the ground moves a bit. Personally I'd get them to rake out to 50/60mm in narrow vertical sections. Plenty of old houses with nothing but sand and dust between the bricks.
I've "raked out" 90% of the joints in a large boundary wall - mainly soil and weeds, with a pressure washer - not a single brick moved.
There's a vast difference between drying and setting. On a hot day mortar will dry out long before it's begun setting, so adding water just reverses the process so is absolutely fine.Absolute gonads!!
Can I add extra water to mortar if it starts to harden on the spot board, to make it more workable again, or should I throw it away?
From Blue Circle .. Once the mortar has begun to set, the addition of extra water will not make any difference as the mortar is now non-workable. Even with or without the addition of water, if the set mix is reworked, this will cause major damage to the structure of the mortar. This will in turn seriously affect both the strength and durability properties and so it is thus vital that the mortar is fully placed prior to the setting time.
It doesn't reverse the (setting/curing) process, that part of it is inevitable, once water is added. The clock has started. It just means the gear is workable.so adding water just reverses the process
I'm not sure just how much of the good stuff, the site batched mix tubbed stuff, actually gets. I think a lot of homeowners would be surprised.Anyway, irrelevant to the issue as apparently it's 1:11.
I'd suggest rebuilding the outside, get the legal guns blazing. I get that you're wary of legal action due to the resale risks. If it all fails and you want to sell then you could choose to not disclose that there's been a dispute, i.e. tell lies. I know this isn't ideal and may be uncomfortable for some, but you're not the one that caused this issue, you're the victim here so I'd say it's justifiable.
I doubt that your buyer would ever find out there'd been any legal dispute. But if they did then they could sue you for the difference between the value of the house with the disclosure and that without. It won't be life-changing even in the worst possible scenario. And arguably if they have a case against you then you could pass responsbility onto the builder anyway, it wouldn't seem reasonable for the fact that the house is shoddy to ever be judged to be your fault.
Get legal advice, explore the worst possible outcomes and go for it. You shouldn't get bullied into accepting crap.
They will resist, probably as far as court, as chances are that the entire estate has the exact same issue. So as soon as they rebuild yours they'll be on the hook for £millions to rebuild the lot. Not your problem though.
Definitely ensure the lab test is 100% reliable first though, possibly get another from another provider.
Thanks ... racking out that deep in perps must be tricky, can't get a disc in them that deep without cutting the bricks?Probably won't crack the bricks like all the others on the estate when the ground moves a bit. Personally I'd get them to rake out to 50/60mm in narrow vertical sections. Plenty of old houses with nothing but sand and dust between the bricks.
How many samples were tested and does your home insurance provide legal cover.Thanks ...
Yes the lab result is very reliable accredited company, one of only two recognised in the UK for mortar testing.
It looks like to get this resolved it will mean tens of thousands in legal bills, I know this from speaking to someone on another development with mortar issues ... BUT the costs can be recovered in settlement ...
