- Joined
- 6 Jul 2025
- Messages
- 56
- Reaction score
- 0
- Country
Hi all
So I just replaced the inner and outer tie rods on my 2010 ford mondeo and after this i had 2 brand new tyres fitted along with tracking alignment getting done ..
A few days after I notice a quiet clunk turning steering wheel side to side when stationery . There is no play in either wheel whatsoever.
Assuming the inner tie rods are loose is it possible to pull back the plastic boot and try to tighten the inner tie rod without affecting the tracking ? Would i need to undo the track rod end from the hub as I try and tighten the inner tie rod ?
I'm guessing this wont affect the tracking as I wont be moving the actual track rod end outta place ill just be trying to tighten the inner tie rod but then if that tightens its obviously gonna move and twist so that's what is making me wonder if the tracking might be out after it ??
It didn't seem to tighten much at all when fitting tie rods back on after about almost a full turn every turn after seemed to wind back on itself which didnt seem right as I did this job on other cars and this hasnt happened its usually allowed me a few turns until actual tight .
I also uses blue lock tite on the inner tie rods .. tia
