- Joined
- 27 Jan 2008
- Messages
- 29,521
- Reaction score
- 3,633
- Location
- Country
The outside light, by my pond, was programmed to light for the milkman, which it has done without a problem, but also was used with other visitors, and it was reporting off-line.
I assumed I had changed a socket adaptor somewhere, which was boosting the zigbee signal, so I swapped around some smart sockets, to no avail, and in the end swapped the bulb, all attempts to switch on/off 3 and 5 times to reset it have failed, TCP colour changing bulb, if that matters.
I also have 4 GU10 bulbs reporting as off-line, but the Google Nest voice command still works, so not touched them. Bulbs have gone down in price, last lot from PoundLand cost £5 each, where I was paying around £12 so not really worried about losing control of one bulb. Over the time when I have been using smart devices, lost three smart light switches, two smart sockets, and one smart socket adaptor, and one (maybe two if this bulb US) bulbs, so in the grand scheme of things, in around 7 years, that's not bad, but loathed to dump the items if there is a way to breathe life back into them.
The sockets and light switches seemed to turn themselves into flasher units. And this is not all one make, so it does seem they are waiting to be programmed in again, but attempts to do that have failed.
Any thoughts?
Any thoughts?
