- Joined
- 22 Aug 2024
- Messages
- 94
- Reaction score
- 3
- Country
Hi.
Sorry if this is a dopy question.
I purchased a Dewalt laser (DWHT77100-XJ measure from Toolstation 5 months ago and have only used it once (to try it) and it was purchased in a sale with plans to use it when carrying out replacing a roof of the conservatory which I am now doing. I took it out to try it yesterday and it seems WAY off. I have the laser set to take the measurement from the base of the unit (Not where the laser starts). The batteries are on three bars (full). I've cleaned the laser with a lint free cloth.
Here is an example.
A gap between the door and the shelving unit.
Tape measure: 500mm
Laser: 554mm (Second measurement was 560)
Door frame:
TM: 730mm exactly.
Laser: 738mm
Chimney alcove:
Laser:1.680m
TM: 1.674mm
I called tool station today to work out if i had to take it into the store or send it back to dewalt. The store is 10miles away so i wanted to make sure before taking it in. The person said "That sounds about accurate for a laser measure. Maybe you need to recalibrate it? We can't take it back for that"
Is this right?!?! I was always dubious about laser measures but i'd heard they were extremely accurate or if they were off it would be by half a millimetre per meter.
I've looked through the manual and can't see anything about recalibrating it.
Any advice?!?! Am i being fobbed off?
Here is an example.
Tape measure: 500mm
Door frame:
TM: 730mm exactly.
Laser: 738mm
Chimney alcove:
Laser:1.680m
TM: 1.674mm
