Hi everyone
My one-year old ariston combi boiler has developed an intermittent (but frequent) fault...
When heating either the CH or DHW, the boiler will cut out (sometimes after 30 secs, sometimes 30 mins). The boiler displays the code "A 01", which apparently means that no flame is detected. Until shutdown, the flame is a healthy-looking blue colour, and everything is working efficiently.
I called an engineer, who checked for loose connections. He undid, then re-tightened , one wire that I gather links a sensor - and the boiler worked fine for a long time (20 mins) before cutting out again. Curses!
I originally thought it was some sort of overheating problem, but this would generate a different error code, and the temperatures reached before shutdown tend to vary from either "warm" to "hot".
When it shuts down there is a noise produced like a very fast ticking (some sort of valve closing?). I'm able to press the reset switch to get it going for a short period.
Anyone have any ideas? Cheers!
