Hi all, I have a baxi bermuda 401 back boiler.
The boilers working fine, no issues with it itslef.
I started the heating, boiler heated the water, all radiators were hot. Except the one in the hallway where the thermostat control is. It was only hot at the bottom. So I figured there was ait in it. So I bled it, air came out.
Than I noticed the burner on the boiler was off. Which was strange as this was less than 10 min and the house was not at 24 degrees yet. So I increased the water temperature on the boiler. Burner started and 2-3 min later it was off. As if the pump is not moving water in the system or the valves are stuck shut. Or the water level is low. It is an S- plan system with 2 valves. I can see the pipe is hot past the pump to the lower valve (vertical), but not furter down (which should be flow).
Can the bleeding be the problem? There was a leak from one tap on pipe that is connected somehow to the system 9 months ago, it was fixed and the heating was working OK since then. All started after I bled this one radoator.
Help much apprecieted.
