Double ditto on that premise dear boy, I think that me and thee might be unusual in that respect though, many electricians have preferred the Red or Brown to be the COM connection on two way switching, maybe back to the old days of wiring in singles (or single and Earth) perhaps.I have always attempted to make the brown (or red) wire the permanent live.
Before harmonisation I never fitted red sleeves to yellow or blue SLs or strappers to distinguish them, in fact it seemed to be a normal thing around here. So seeing a red in a com it was assumed to be the perm or SL of a conventional system and the first time I came across blue perm at the distant end of a faulty 2 way conversion system caused some head scratching.Double ditto on that premise dear boy, I think that me and thee might be unusual in that respect though, many electricians have preferred the Red or Brown to be the COM connection on two way switching, maybe back to the old days of wiring in singles (or single and Earth) perhaps.
But yes I have always preferred the Perm L colour code to be L non sleeved original and the sleeving, where required, to be on the others.
Sort of "Only original L is the Perm L" idea.
I think it`s more logical. Plus with a straightforward Feed and Return for one way switching on T & E cable then if not twin Red (Brown) used then the Red (Brown) is usually Perm L and the Black (Blue) sleeved appropriately is usually SW L. Makes perfect sense to me!
Awhh you nawty boy, I thought I had found a kindred spirit here my friend.Before harmonisation I never fitted red sleeves to yellow or blue SLs or strappers to distinguish them, in fact it seemed to be a normal thing around here. So seeing a red in a com it was assumed to be the perm or SL of a conventional system and the first time I came across blue perm at the distant end of a faulty 2 way conversion system caused some head scratching.
what do the Red White Blue generation think?
I was actually instructed on a course (terminating SWA) around 1974 that phase colours dont require marking when used as L, only if being used as N or EAwhh you nawty boy, I thought I had found a kindred spirit here my friend.
Yes I had hanks of red sleeving for those yellows and blues, all my switches were Reds, the true Red was L and the others (Yellow and Blue but sleeved Red were the SW ls.
Initially I, like so many, used harmonised black as N and gradually found others using grey which I didn't understand... until re using an existing 3ph cable for single phase and automatically wired as:So once we changed to those Nasty Brown Black Grey the Brown sleeves were easy.
But it had been extended with harmonised and suddenly grey = N made a lot of sensewith Red being L yet Blue being N even when Blue was N for flexes then by default yellow became E because the E was green/yellow for years after green was E.
Don't forget the red, white or yellow, green, neutral blue and bare earth or red, white, blue, black, black generations and of course the DNO were a mind of their own which I've seen a number of timesFunny how your quirks and foibles are biased towards the gen consensus of practices at the time of your indoctrination of the ways of the word at the time you became aware of how the world might work..
Although mine make sense to me and might do to a lot of others there are some who have other inclinations to bias that have validity too.
However it changed a number of times over the years before that combination so not surprisingly it did changeI really miss the Green for E but even I appreciate the G/Y as a better Earth option even back in those days - partly down to my age and the era of my experiences.
I vividly remember the "Brown and Blue is ONLY for flexes and Red and Black is still for fixed wiring AND THAT WILL NEVER CHANGE!!!"
LOL
The original 'New colours' for a 5 core flex was widely publicised as 3 browns on posters in all the wholesalers, education establishments etc. I clearly recall the poster on the wall of our junior metalworkshop at school (so I would have been no older than 13-4 or 1968-9) and us discussing how dangerous it looked but the metalwork teacher trying to convince us otherwise. All the magazines involving electrical content of the era ran articles such as practical householder and even in my mothers womens magazines such as womans own and her asking me about it.As a yong lad and during my early work years Green was E before it changed to the "New" G/Y Combination, even though in T & E etc it was often left bare and nobody seemed to mind much, it was quite common.
brown and blue for single phase flex was the "new kid on the block" later and everybody said, "only for flexes, the fixed wiring would "Never Change!" LOL.
4 core flexes had a black core and 5 core flexes had two black cores (Oh Heck!).
Hmm post #26 https://www.diynot.com/diy/threads/electric-shock.644667/page-2#post-5974927In fact when I started to mention at the wholesalers that our fixed wiring was going to change to Brown and Blue they all thought I was off my rocker. I had read it on the Voltimum Website.
When it finally was agreed that Brown/Black/Grey were to become the three L colours it was supposedly researched with the conclusion that it would only kill about 12 or 14 Electricians, so low risk and acceptable.
No I don't like them, one of my biggest gripes is they are often very similar colour, especially low smoke versions or talc filled cable.Have have never liked the three "Killer colours" as I have called them
What else could be more obvious than the three pigment primary colours for the wires that hurt and lack of colour for the one that doesntand I greatly prefer the Red/Yellow/Blue idea with Black for N.
✔G or G/Y for E I dont mind either way but I suppose that looking back G/Y does seem more sensible than G nowadays.
✔RYB sleeved Red where appropriate does look prettier than Br/Bk/Gry behind ganged switches in my humble opinion too.
I think the vast majority of electricians will have wanted to retain their countries standards as the best combinationI did hear a few years back that many European Electrician types finally admitted that R/Y/B was a better idea than what we have now but at the time it was decided did not want to favour the UK advantage it could have brought, not sure if that is officially actually true though.
6 primary colours? I'm only aware of R,Y,B, for pigment and R, green, B for light. Unless Cyan and Magenta are now specified.When I attempt to look at it objectively then my thoughts are R/Y/B being 3 of the 6 primary colours often used in everyday life and each one stands out from each other, even to many colour blind folks (I have never met anyone who has monochromic vision though but I have met quite a few colour blind folks), Black for N I easily go along with but I dont rule out others instead, personally, if required.
✔Anyway, thats just my take on things after all, others are free to disagree.
In low light and especially in LED torchlight the Bn,Bk,Gy, are far worse than R,Y,B. More than once I've found 400A powerlocks plugged up out of sequence, often done under low light condittions and a LED headlight such as under a temporary stage.I do realise that the old white could often become a bit yellowy, especially in industry and again that some variants of RYB can become more indistinguishable in low light conditions as well.
No there are 6 (main ones, others are possible though apparently).6 primary colours? I'm only aware of R,Y,B, for pigment and R, green, B for light. Unless Cyan and Magenta are now specified
Right so Magenta and Cyan (which are attainable from R,Y,B) are now classed as primary colours?No there are 6 (main ones, others are possible though apparently).
Two groups 1/ Emitted light from the stars, a torch, a TV set and they are additive - RGB (Red, Green, Blue).
2/ Reflected light (cos they absorb the others) such as in dyes, inks, paint etc they are subtractive (Cyan, Magenta, Yellow) .
So using two from one main group and one from the other group does not seem too bad - cos they do stand out and distinguish quite a bit.
Artists do a 2 & 1 juggle too and nobody minds really.
Conversely by mixing two primaries from group 1/ you get result of a primary from group 2/ and vice versa.
Good innit?
And is merely a highly simplified version of events
One of my favourites is Bn,Bl,Bk,R,Gn/Y
That photo looks very familiar...... and of course the DNO were a mind of their own which I've seen a number of timesView attachment 391195
