Enamel galvanised steel
28 Jun 2021
Hi
I want to apply spray enamel to galvanised steel angle L shaped from SF part No. 880JP. Do I need to spray metal primer first and then the enamel or can do without primer?
When I paint galvanised items, I always use a preservative primer.
They are available specifically for galvanised metals. It is considered a difficult material.
They are quite expensive. I mostly use a dulux product but other makers of industrial paints also make them. You will find the tin surprisingly heavy. They usually say allow the zinc coating to oxidise before painting.
I live in a coastal region and outdoor steelwork is very prone to premature rust.
I apply by brush. For small, glossy items I thin it first in a small pot and apply two thin coats, because the primer contains a lot of solids.
Consider using an etching primer.....the difference of adhesion is dramatic compared to the ordinary stuff.
John
In the old days, when painting galvanised Crittalls windows, I used to use zinc plumbate primer. Now I use waterbased primers designed for galvanised metal. The last one I used was a Fortress paint.
I applied Rust Oleum surface primer this morning; 2 coats, says to wait 12 hrs before paint, adhesion looks quite good, will enamel tomorrow, there is no rush, will update the result.
A tiny tin, but a very reasonable price for a small job.
