Volts x Amps = Watts
15 Dec 2009
Whitby N Yorks
Whenever I look for electrical cable I am immediately confused. I remember V x A = W from school 60 years ago.
Situation is I need new wires for the navigation lights which are up my yacht mast. The boats electrical system is 12v and the light bulbs are 25w. Therefore according to the formula I only need 2 amp wire. The cable run will be +/- 15 metres.
I am looking at some cable on ebay. Oceanflex marine grade 2 and 3 core tinned 12v/24v 1.5mm 21A overall diameter 6.1mm.
Although this wire seems massively over the top considering it is 21A and I only need 2A please could anyone advise if this would be a good choice?
Mike
It fulfils the electrical demands as long as there is only one bulb per run of wire.
Ability to resist the harsh environment is probably far more important for your application
Yes, Volts x Amps x PFC = watts with AC, and no PFC with DC, but with modern bulbs they have a built-in switch mode power supply, so typically 10–30 volts, so 25 watt at 10 volts = 2.5 amps, and at 30 volts = 0.83 amps, not that this really changes the cable required, as to be strong enough not to be damaged unlikely to find cable under a 5 amp rating.
Thanks for replies.
Only 1 mast but 3 bulbs.
At masthead there is a combined unit tricolour and anchor light. The tricolour has only 1 bulb but a triple colour lens. The anchor light has 1 bulb. The anchor light and the tricolour lights will never be used simultaneously.
There is also a steaming light half way up the mast on a separate circuit which requires 2 core.
The next wire size is 2.5mm/29amp
Mike
The wire size referred to in my original post is 1.5mm 21A.
As far as I am aware the next size up in the Oceanflex marine grade (tinned) range is 2.5mm 29A
Perhaps there is a 2mm?
As I said in my original post this always confuses me.
Mike
Mike
from 60 years ago teacher said Womens Voluntary Institute & Very Important Rat
