running CCTV cameras off a solar panel
7 Sep 2025
Greetings!
At the moment I have 2 Tapo out door cameras and one Calex indoor camera running off of a 110Amp/hr battery that I keep having to bring home swap and charge all the time.
Would like them to run off of solar panels and the 110 battery on there own. So any ideas please on solar panels to buy?
PS the 2 Tapo cameras are 9 volt, and i have a drop plug for them to work and the Calex is 5 volt USB
No, it is more they use mppt regulators etc. And so know which ones work best. I can look at my solar, which is 6 kW, and tell you in mid-wales how much that produces each month on average, May 901.2 kWh and December 97 kWh so you can work out what you need. But the narrow boat people can tell you what the panels do when mounted a lot lower and only producing 12 volt.
Bluetti make solar generator kits which might be suitable for this purpose.
I got a small panel with the idea of maintaining the caravan battery, set it in the window of the caravan, but it was useless, would have been better off simply disconnecting the battery. But a friend did the same with a tractor, and it did seem to work.
If I walk around my garden, there are lighting spikes my wife has bought, some seem to run for years, others have died after a month, and some spring back into life every summer.
The internet is full of kits 1757407164493.pngand we have no idea which do and don't work after a year of use. 1757407311445.pngthis looks good, but how long would the power pack last without the solar panel, we don't know,
The problem is lithium batteries are rarely 12 volts, so all the time we are using them we are also powering an inverter, and lead acid batteries take power just to maintain the battery, so more worried about losses to what the camera uses.
So an 80 Ah fitted to wife's car, AGM type, over Colvid was switching the charger on once a day, nearly always same time, so assume the car was sending info back to Jaguar? But the power use was very low. Also, 80 Ah also reasonably new, on a Kia, this time a flooded battery, was needing 4 times what the Jag was using to keep battery maintained, and the little Honda Jazz with something like a 40 Ah was also using a lot compared with the Jag.
But the 35 Ah AGM on the mobility scooter used even less to the Jag. And the 20 Ah AGM in the jump start battery pack even less again. So we have to ask is it worth it? I can so easy recharge the jump start pack, and so easy to carry, likely better simply charge it up one a month, I looked for a Tapo 9 volt camera found this 1757409092383.png but nothing to say how much power it uses. But there will be losses with the devices to get 9 and 5 volts from a 12 volt battery, well not even 12 volts really on charge can go to 14.8 volts depending on charge controller, and most droppers have an auto switch off at around 11.8 volts.
I was looking at using 2 x 80 Ah batteries which were on a car as emergency lighting, and I still need to look at cheap methods, I have a lead, Emergancy power kit.jpg so two cig lighter sockets on croc clips so easy to connect to a battery. So two methods to use it, I have lights designed to be used when working on the car, small tungsten bulb, and a magnet to hold it on the bonnet, and also some USB adaptors for a car, and USB desk lights. As yet not measured how much each uses, ones first impression is the LED USB will be better, but there will be losses getting 12 volt to 5 volt so until I measure I will not know.
I, in real terms, could not care less if they run for 6 hours or 6 days, I have enough charged batteries around. But your step one is to measure how much they use. Easy for me, I have an array of meters to select, likely will use this one,Diffrence line neutral 8 Feb 24 reduced.jpg ⁣but that is up to you, until you measure, it is pure guess work.
The internet is full of kits View attachment 392218and we have no idea which do and don't work after a year of use. View attachment 392219this looks good, but how long would the power pack last without the solar panel, we don't know,
Those kits look like they come with the battery included
View attachment 392220 but nothing to say how much power it uses. But there will be losses with the devices to get 9 and 5 volts from a 12 volt battery, well not even 12 volts really on charge can go to 14.8 volts depending on charge controller, and most droppers have an auto switch off at around 11.8 volts.
guess work.
That is the camera I use (or 2 of them) typically a 110amp/hr battery lasts a week before it needs recharging
110 x 12 / (24 x7) = 7.85 watt/hours. My 6 kW solar panels clearly can produce a lot on sunny days, but December 2024 they produced 97 kWh = 130 watt/hours average. So 6/130*7.85=362 watts. So you will need a 400 watt panel to run the cameras.
Google and I get
I also get
at £25 yes I would take a chance, but at £400 no.
Google and I get View attachment 392436I also get View attachment 392437at £25 yes I would take a chance, but at £400 no.
Some people would say you get what you pay for; but nower days that is not alwways the case! BTW i have been on a caravan forum and they recommend a 100W solar panel is enough. did i mention above that a 110amp 12volt battery lasts about a week
