Good Evening All
I have a problem with a leaking old lead pipe feeding from our bathroom to cast iron downpipe which I previous posted about here:-
www.diynot.com
I got some good advice re trying to remove the pipe from the bathroom side first and where to cut the cast iron branch in order to join some 40mm pvc waste pipe, which I hope to replace the lead pipe from the bathroom with.
Anyway, I ordered some carbide blades for my reciprocating saw but in the meantime I was thinking about the join on to the cast iron again and the best approach. The funny thing is that I noticed one of my neighbours appears to have had exactly the same issue at some point in the past:-
Lucky for them, they don't have an extension making it an internal issue but you can see they've done the same thing and cut the cast iron back and now have a smaller pipe coming from their bathroom, with some kind of mortar repair around where they must have bust the branch off the wall.
My question is - What kind of join have they got in place here? As a complete layman it looks like something has been set into the cast iron side and held in place with some kind of putty / sealant but I guess its got to be something better than that?
But anyway, given that's the exact kind of join I need to make, does anyone have any suggestions of anything more modern than this which would be better?
Best I can think is something like this:-
But I'm not sure if that's a great thing given the downward flow of water from the smaller side of the connection to the larger...
Thanks for reading and I'd be gratefully for any advice anyone may have.
Leak From Bathroom Sink / Bath Waste Coming Underneath Old External Wall Cast Iron Joint
Good Afternoon Folks I have a tricky issue here which I am hoping someone may be able to offer some advice / recommendations with:- We have a leak which has developed somewhere in the piping between our upstairs bathroom and the joint to the old cast iron elbow (? sorry, think that's the term)...
www.diynot.com
