Connecting basin waste to cast iron pipe
10 Dec 2018
I have an old cast iron waste pipe, and need to cut it so I can replace my bathroom basin. Can I just use plastic compression fittings to couple plastic pipe with cast iron? The iron pipe looks more like 40mm rather than 32mm.
CBW
26 Sep 2019
North
Yes, I’ve used these successfully in the past. Just make sure it’s clean, free from grease debris etc.
3 Feb 2008
Northamptonshire
Waste pipes wont be cast iron. Choices would be, copper, mild steel, or lead, but Compression Waste fitting should be ample to make a connection. Just be careful if cutting lead, it may collapse out of shape if you're too heavy handed.
28 Jul 2009
Kent
I have to disagree on this one. My 1965 house was CI soil pipe and the 2 branches for basin and bath were 2¼" (external diameter) CI, final piece to trap being brass compression fittings and copper pipe.
Verry unexpected.
4 Oct 2012
East Renfrewshire
Technically the 'waste pipe' was the copper and the 2 1/4" CI branch was classed as part of the stack. The CI stack and branches were hemp and lead soldered together so were then considered all the same pipe. The transition to copper would then be classed as the waste pipe which is now 32mm/40mm plastic.
That being said some of the older basin s traps were purely formed lead with a wiped joint straight into the cast, Ive got one of them sitting outside just now in the scrap pile.
28 Jul 2009
Kent
If the smaller sections didn't meander around I'd have happily agreed, the basin was 2x 3ft lengths a short bit and 2 elbows, bath was a 6ft length, 4 short bits and 3 elbows.
Both ran into branch tees in a horizontal section of the 4" foul, is it still called the stack if horizontal?
All of the wastes in our 1951 house were lead as you describe, albeit all ran into hopper heads or gullies.
4 Oct 2012
East Renfrewshire
That's a good question, I was always told and it was always described that any part of the cast iron pipework whether it be the main stack or the toilet soil pipe or smaller permanently connected CI branches feeding into it as part of the stack. Any smaller non cast 'moveable' internal pipework was then called the waste run.
28 Jul 2009
Kent
One of the 1930's office buildings I worked in was exclusively CI in the toilets.
Pans fed direcly into CI collars (smaller than 4") as did the brass U-bends into a smaller size.
Accordingly there were no waste or soil pipes, just a stack?
4 Oct 2012
East Renfrewshire
Soil pipes were always classed differently due to what they carried, grey water with matter in it, waste water was anything not from the toilet. With the old CI designs we were always taught that the feeds into the vertical stack were called branches and the waste pipes were usually only small connecting pipes (11/2" usually) that joined the traps to the branches.
When regs, materials and designs changed then actual waste pipes (pipes connecting waste traps to the soil pipe) became longer and were then used to connect traps directly to the soil pipe/stack so branches were no longer needed. TBH though waste pipes are used too handle too much these days and become an endless array of blocked and restricted pipework. This is usually because they are too small to handle the volumes or distances they are being asked to cope with and that's usually due to bad planning/setting out/workmanship.
