old copper basin waste pipe
25 Jun 2009
South Tyneside
hi guys,
does anybody know if there is a compression coupling that will join a 28mm copper waste pipe to the new plastic 32mm
see picture attached
View media item 35466
left is bath
centre is basin 28mm copper
right cast iron stack
Id start from as close to the stack as poss on the horizontal pipe with a 1 1/2 mcalpine connector and renew the lot in plastic for two reasons
1- copper will corrode and eventually have holes in
2- scrap is worth a fortune and you may even make a profit on the job
Looks about 33mm give/take.
looking at the connection on the bath waste the connector looks like 32mm one end and 40mm the other end.
why not cut the horizontal pipe fit a 32mm compression coupler and then
run the rest in solvent weld pipe up to bath/basin.
the pipes are the old imperial type
so the horizontal copper pipe is 1" inch (internal diameter)
the vertical cooper pipe is 3/4 (internal diameter)
dido
