Installing new toilet to existing cast iron waste pipe
12 Aug 2006
Anglesey
Hi there, wonder if you could help me with regards to fitting a new close coupled toilet to a cast iron waste pipe.
Currently the cast iron pipe is approx 200mm out into the bathroom on on a slight angle upwards
How far back would i need to cut the cast iron waste pipe and what sort of fittings or adapters would i need to join the new toilet into the cut cast iron pipe?
use a pan connector
align the toilet and cistern up and measure and you'll see what type of pan connector you need long, short, offset etc and how much you can take off the cast iron waste.
Thanx for the reply, i will require a offset connector, so basically its just a push-fit connector??
