fitting needed for tap font to sink
7 Sep 2025
Hello!
Have a standard size/ type domestic kitchen sink. And I have a duel pipe tap that i wish to fit. but need the correct fitting so it will bolt on. please see the photo below
You have there a Monobloc tap, to fit a single tap hole sink. If you wish to use a Deck Mixer with two inlets, you'll need a two tap hole sink. Otherwise fit another Monobloc mixer.
pass! dont understand any of it
BTW went to screw fix and could not help
It says mono on that. though mono was singular and not plural. but there is a hot and cold feed inlet (=2)
Monobloc = single hole through the mounting surface, with both H &C pipes going through that single hole.
JimCrow, has provided a link above, to what you need, to mount that monobloc tap, to your single hole, in your sink.
